Not bad for your first Omega 馃憤
@watch72 How small your wrist is?
I have a small wrist too (6" 1/4 - 15.75cm) and thought the same. Then I had the occasion to try a Speedmaster Pro, tried it thinking it would be too big (not truly thinking about it TBH because deep inside I already knew it would be too big) and I ended very surprised! For sure it is bigger than my reduced, but it is not that big. I am fairly confident no one will find it "too big for me" the day I pull the trigger.
I realized afterward that the 42mm is truly the case diameter, which is asymetrical. A Speedy wears closer to its bezel size, which should be something like 40mm.
If that can help to have a better idea of what I usually wear, my biggest watch ("physically" but also "visually" speaking) is a Hamilton Khaki Field: 40mm diameter, 49mm lug to lug, 12mm thick. Depending of the shape, I may be able to go 1mm longer but that's it. I tried a HydroConquest 41mm a long time ago and it was a bit too big.
I think the Pro wears even a bit smaller than my Khaki, so, definitely not "too big"
