Hey guys, I must be a very sceptical person and all that, but is it custom for Omega (Museum) to valuate a watch?
I have had some emails back and forth with Bienne, and without exception, their English is impeccable -better than mine. Might be the 'someone, telling someone' etc., but 'likely the servicing group at Bienne confirming authenticity of the watch with the museum", mmmm, I would like to see some more details and all, to meander in that direction. With all due respect (and I mean that!!!) to
@Archer .
On the dial itself: I have done some enameling in the far past, and usual, the enamel 'flows' evenly on the surface, while being in the furnace. Even if there is an uneven underground, it is not likely (as in 'never') to end up with an un-even surface. Let alone the bubbling between the 3 and 4 o'clock markers.
And if scratched, the enamel will hold its color, which seems to be scratched off, around the 2 o'clock marker. And the process of painting enamel is 'de facto' useless IMO, since it will hold very badly -unless you fire it up again, and you will have a much better, deeper color when you do the enamel right the first time.
Few other things: the 11 o'clock marker is of a different measure as the others, the 2 is missing (obviously...) the 3 is askew (....), the gold-color paint near the point of the 10 is repaired (rather clumsily), as well as visible of loss of 'green' next to the 10 o'clock marker.
Raised some doubts in my mind if the dial is enamel. But that might be me only.
Questions, questions, I know, but that is why we are here on this Forum, unless I am mistaken
