I'm also on the hunt for a 145.022-68 'Transitional' DO90 Bezel.... how do this look to you all? I know its worn, but is it correct?
Over all appearance. Patina can look killer, or look horrible and sometimes inverse in pictures. nothing stands out to me as an issue on this one if you’ve checked the numbers well.
seems that the above is a 145.012 Bezel... for a 321 movement. I don't think this will fit my 145.022-68 'Transitional' as its an 861 movement an has different feet. https://speedmaster101.com/145-022-transitional/
??? Your asking about a bezel, there is no dial feet on a bezel. Hint: Feet are on a Dial... Bezels are interchangeable for the most part across all 42mm speedies... (FOR THE MOST PART)
