Hi Keith,
Omega has changed case numbering systems over the years to add another digit. This is why when you look on the Omega vintage database, you often have to add an extra zero. I can look up cases with with 168005, or 1680005, and get completely different results. Sometimes using the original number comes up with no result at all, so then it's easy to know what you are asking for, because there is only one option. For this one I get a result for both 168005, and for 1680005.
I gave you both options because the obvious one (055ST1680005 so just adding the extra zero before the 5) didn't have the diameter crystal you said the watch case needed, so I looked up the other and included that for your information.
Now it seems others have determined the case is a franken, so that explains why it's not working. Coincidentally, I also a 168005 here that I am having a similar problem with, but for mine the normal crystal 063PZ5016 is too large for the opening in the case, not too small as yours is. I suspect mine also has a franken case, and identifying the case frame so I can get a new Omega crystal will be difficult...
