Hi, I own an heirloom Omega Constellation C-Shape quartz (like the one pictured), which I believe is a model no 198.0111 (I think 1977-1984). It's gold capped and could originally could be bought with a gold capped bracelet AFAIK. It's 18mm between the lugs (unlike the older C-shapes which I believe were 19mm). Does anyone know what the bracelet was called? Or the end links? Or if there is another matching bracelet with curved end links (Omega or aftermarket) that would be a good fit?
When I search on this case number, it only shows straps as an option - bracelets come back with "no results found" so not sure if ever came on one...
You should ask the person who posted those photos. The end links appear to be stamped 144, but again searching on end links with that number comes up with no results. Also searched on entire bracelets with that number, but none have 144 end links...
