I need a second/sweep hand for a 168.005 pie pan, stainless steel model. Are there any sellers in the UK who would likely be able to supply one? Otto Frei supplies them, but shipping costs are nearly 3 times the cost of the item. I also need a crystal retaining ring, can I buy these separately or do I need a new crystal, and can someone please tell me the reference number? Thanks Nick
Have you tried cousins? http://www.cousinsuk.com/ you need to register to see the omega stuff, but its free/instant...
Thanks Mothra Does anyone know which is the correct sweep hand. they have 2 stainless steel hands for this movement 066UZ1365 and 066UZ1377. One I am assuming is for a pie pan and the other for the dome dial which I assume is longer. Thanks
Only thing I was able to find on the Jules Borel database is that part number 066UX1365 is described as "HAND, YEL SWEEP SECOND 12.5MM". The "Z" probably means steel. There are some other hands that are 13.25MM, so those may be for the dome dials. You'll just have to measure them out, gatorcpa
Thanks mate I've just ordered one anyway (066UZ1365) so I hope its the correct part Only £8.53 so not the end of the world if its the wrong one.
Are you looking for all steel, steel with a gold medallion, 14K gold or 18K gold? All of these versions exist. Unfortunately, Omega does not make these anymore. eBay is your only hope. Most of those are well-worn and very expensive. Best best is another watch, but even these are pricy nowadays. Good luck with your search. gatorcpa
Unfortunately that one is too long for a pie pan. You need 066UZ1355 which is 10.5mm from collet to tip.
I do not have permition to post at WTB. And honestly i do not see problem in do ti. But OK. i am new here.
It is against the rules. I let it go once. When you start posting your request in every thread that has a Ref. 168.005 Constellation, I have to delete them. gatorcpa
