Citizen Para Water Auto Dater UNI crystal replacement
Hello, my Citizen Para Water Auto Dater UNI crystal replacement.
May I request some assistance?
I'm in need of this for my broken one.
Thank you Wayne
There are a number of references with this general designation, so it would be difficult to give you a link. However, I would suggest keeping an eye on Yahoo! JAPAN listings. There are several crystals currently listed (e.g. https://buyee.jp/item/yahoo/auction/l574675534?conversionType=search_suggest) but I don't know which one would be correct for your specific variant. You should try to determine the part number. Also, I think it's quite likely that most crystals you find will be aftermarket.
Thank you for your reply, I've searched all the sources I can find, Germany, Japan, Neatherlans, ebay, offer up, watch suply houses, I can't locate the crystal number, I have the case number only.
A photo of the watch might help. Is it the type with two crowns or one?
There's a guy on the wristsushi forum that has a huge stash of citizen and seiko crystals for sale. You might want to ask him.
Hi Dan,
I just purchased an Omega Speedmaster 321 complete movement, it also has the case back dated 1966, it cane with some other items I purchased.
Unfortunately it has no case middle or bezel.
Wayne
Hi Dan,
Wayne
I assume you will also need pushers and crown. You can find all those parts, but they will be quite expensive, roughly $5k USD. For that year, you will need different mid-cases depending on which company made the case-back. It should say either HF or CB. If you don't want to spend the money to restore it, you might just want to list those parts separately on eBay. They will make you some good money.
