Choices… Omega Seamaster Professional 300m Quartz or?
If I decide on the Omega I will replace all the seals.
Turns out I check all functions and the corrosion causes the date wheel to jam so service it is!
Getting this serviced and fixed rather than replace the quartz movement.
If you send the watch to Omega for service, you may get a new movement as well. The caliber 1538 had at least 4 versions (A, B, C, and D). It is my understanding that if your movement is not the latest revision D, then Omega will (may?) replace it with a revision D to bring it up to specification.
You can ask not to replace the movement. But with the water damage, serviced can't be avoided and lots of parts will be changed ; for the good in that case... 😉
