I have case numbers but where do i find the watch that this substituent Thanks for any help Kind regards Roel 5670011 5660024 5650005 5350015 5350007 165003 1961516 / 1961526 1650027 1450018 1450007
Still a bit confused, do you have these cases and want to know what the watch looks like? Or are you looking to buy these watches and want to know where one would find them?
some one gave me the numbers of omegacases connected to my bracelets now i need to find aneasy way to find the watch 5671 fully stretchable 13mm 5670011 5726 nr 11 with end links 546 13 mm 5660024 5707 nr 12 with end links 542 13mm 5650005 5898/147 nr 12 20 micron met vouwsluiting 5350015 5684 13 2/68 end links 537 half stretchable 16mm 5350007 1122 28 0/1 pat 896575 fixoflex s with end links 558 omega 18mm 1036 nr 12 with end links 512 18mm 165003 1501/823 nr 32 endlinks are fitted to bracelet L 16.5 cm W 18 mm 1961516 / 1961526 1206 nr 32 gold plated 20 micron with 3 end link 673 18mm 1098 gold plated 20 micron end links 540 19mm 1650027 1167 nr 11 19mm 1069 nr 12 end links 658 19mm 1172 nr 11 with 3 end link 538 19 mm 1450018 1117 nr 11 22mm 1450007 1155 26mm 1163 nr 12 gold plated 20 micron end links 702 26mm
Ah, ok. At least we understand now. Hmm, Google those ref no. perhaps? Sent from my iPhone using Tapatalk
Try looking on the Omega Vintage Database. Use the format: XXX.XXXX Some will be there, some will not. Some won't have pictures. gatorcpa
