Anyone have any ideas what this bracelet goes to?? I'm reading a deville power reserve but duplicating that info has been difficult. Whats the difference between the 1600 and the 1601? Also the watch ends vary from 940, 941, 942 Can you provide some insight??
Indeed but which ones?? Some are 20mm and some are 19mm and I cant figure a way to distinguish them apart i have verified that the 1600 and 1601 can be 19mm so maybe the end links are different. Im messaging Ofrei now to get some info.
I don't think they are very common... I've been looking for a deville gmt with this bracelet on ebay and watchrecon now for about six months. I've seen two come up....
Hi John. Nice Deville..... Btw how do you adjust and fit the modern brick bracelet? IIRC the vintage one you have to cut it and it will not be repairable once already cut.
Never happened to me to have a bracelet fit after first try. Good to know those modern brick bracelet could be fitted by pin.
Reviving this old thread. So a 1600/940 is 19mm width? What about 1601/942? I'm looking for the 19mm size version
Nice collections of DeVille.. I’m looking for a bracelet for mine too.. but as the OP i cent figure out the difference.. could it be the finish? Satined vs polished perhaps? The strap my watch has its a 20mm so I would imagine I should go for that one, although I’m a bit sceptical as my version is the satined one and the bracelet is most likely polished.. any advice?
Interesting. I think I now own this watch. At least if yours was number 845, but how many 541.31.31s do you see on an Armadillo.
