hello all, is it normal on a seamaster poc for the bezel to be easily turned? it seems like when i dry my hands off with a towel or bump it on something the bezel turns. is there any way to adjust or tighten it? thanks
Not exactly sure what model you have, but if it is an older watch the click spring can get worn down, and cause the bezel to turn more easily. It's a cheap part to replace. Cheers, Al
sorry Al, its a seamaster planet ocean chronograph co-axial 600m thats about two years old. thanks for the info
Sounds like the click spring is loose, so that is a cheap part - just get someone who knows what they are doing and has the right tools to remove the bezel. Cheers, Al
