Photos is of my newly acquired BOR ....... I have a question I own a vintage Seamaster 120 case number 135027 lug width 19mm ... wondering if i can fit 18mm BOR bracelet on my 120, I have just secured myself an Original BOR omega bracelet 18mm ... need some advice on this matter
Now that I studied the two different bracelets, the 1503 shown on the 120 is a 9 row BOR (7 narrow beads, two wide) with the necessary end links to fit your watch perfectly. The one you have is a 7 row BOR (5 narrow beads, two wide) with as you said, 18mm end links. You won't be able to fit the wider end links to your watch because they won't attach to your bracelet. You can probably attach the bracelet you have, it will just have a 1/2 mm gap on each side. Try it and see if you like it.
Any idea what 18mm end links would come on a 166.002?
There are at least two different round shaped end links in 18mm for the 7 row, any of them would fit your watch (511 is one number). The 9 row has sharper edge profile that I think would go nicer on your watch.
I do like the 9 row much better. Is there only one choice for end links in 18mm for nine row? Sorry for all the questions..
ok boys and girls .... just managed to secure a 22mm BOR bracelet solid stainless steel from ..... " Yobokies ".... play on words ... seikoboy spelt backwards ... he usually does mods for seiko .... but he also has watch parts ... sharing is info who knows he might be able to help U out
