rogart
·I prefer a manual watch because it's easier to wind up to full throttle than a automatic .
In most cases you can wind your automatic watch, just like you do your manual watch.
When i like to wear a automatic watch I take it up and it start ticking . Set the time and date . Wear it all day and then when you go to bed .Put it on your bedtable . It's stops during the night . Why ? Because it's not wind up enough .
TWhen i like to wear a automatic watch I take it up and it start ticking . Set the time and date . Wear it all day and then when you go to bed .Put it on your bedtable . It's stops during the night . Why ? Because it's not wind up enough .
That seems very odd. All of my old bumper automatics will be wound enough during a day's use to make it through the night, still ticking away happily. And that is from stopped, without doing any manual winding at all.
Funny, I'm not a particularly active guy but I don't have this problem that's been described. On most watches with a power reserve of 38-42 hours, I wear the watch for about 12 hours a day, and it seems fully wound. Which means I take it off Mon night 8pm, and the PR keeps it going till I pick it up again Wed 8am (ie. 36 hours in between). Seems to work whether vintage or modern, so it allows me to alternate watches without using a winder.
+1, I have the same experience with my automatics...maybe you're automatics need
servicing Rogart, or you're dead.😉
@NT931 have you ever tried it on a completely empty watch that has stopped . Wear it for a day and put it on bedtable . Does it go all night ? No winding crown just shake it so much it starts working . Set the hands and date if there is . Does it wind up so much that it's fully wind and go for 48 hours ?
How many times to you have to wind it to get a full charge?
