This article has been mentioned before. As I said last time, I would take these "problems" with a grain of salt. I install hundreds of Omega acrylic crystals every year, and I can't remember the last time I had any trouble with one. If he is having problems with these it's likely either an equipment or technique issue, not a problem with the crystals.
The pushers he mentioned (the press fit style) are not meant to be disassembled for installation, as they can be pressed right into the case fully assembled. Omega purposely puts Loctite on the threads of these to prevent scenarios where the pusher caps unscrew and fall off. Only the screw in pushers are meant to be disassembled for installation, and they don't have the Loctite applied to them from the factory, so that's done on installation in the field.
Fitting new hands is part of watchmaking - I don't know any other watchmaker who complains about this. Very common with chronograph hands as they have to be fitted tightly to the posts so they don't move on you when the chronograph is reset.
Same with the rotor bushes (proper name is pinion) - they are intentionally left undersized so they can be reamed to fit the axle - Omega offers 2 different diameter reamers for this task.
Bottom line is that the problem is not with the parts...
