I can't tell you the thread off hand, but since you have a new pusher body it's simple enough to measure that to get the information required. This won't be a simple repair unless you have some decent machinery, as the case needs to be set up at all the right angles when you drill the hole larger for the sleeve you are contemplating. I think you are somewhat lucky this is a Mk. II case, because you probably have enough material to get a sleeve installed that will give enough wall thickness to cut new threads.
If you have a new pusher in the package, there will be the Titanium washer in the package for when the new pusher body is screwed into the case. I use red Loctite on the threads also, as per Omega procedures.
Good luck with the repair - hopefully you can find a machine shop that will take the time to do it right, and not charge you more than the case is worth.
