Hello all, I would like some advice please. Is the Aqua Terra Quartz 36.2mm (2518.30.00) the same as the Railmaster 36.2mm (2504.50) automatic . So the only difference is the see through case back? So in other words, would a railmaster movement fit into a quartz case? Many thanks, Nick
The coaxial movement of the 2504 is thicker than the quartz movement of the 2518. It is possible that both share the same case, but the movement inner spacer / ring and the caseback would be different for sure. If you want to put a 2403 coaxial movement on the 2518 case you will need at least the proper spacer and a new caseback Sent from my iPhone using Tapatalk Pro
