I removed the bracelet from my Aqua Terra and it looks great on the strap. My problem is that I cannot get the bracelet back on... The end link fits perfectly but the spring bars obviously get in the way. I can't seem to get the end link lined up and in when I insert one end of the spring bar into the lug. I don't want to "force" anything. I am relatively capable but not coordinated enough to use 2 tools to compress both sides of the spring bar at the same time and insert the end link. I can't believe that it is this difficult, so I am hoping that there is a technique or a trick. Please help!!
You need an Esslinger springbar plier. Do a Google search and you'll find it. Sent from my SM-G930T using Tapatalk
Here is a pic of the spring-bar pliers that I bought off eBay. If you like to swap between the bracelet and strap often, it comes in handy.
