I just bought à AT ref 2512.3000 And i got my lug size to 21mm. My plan was to get à omega original mesh bracelet. But they are only in 16,18,20,22,24 mm. Thats make 20 to small and 22 Will not fit ;( any ideas. Or maby there are som special end links to put on the 20mm mesh to make it 21 ?
I'd go with the 20mm. You wouldn't really notice the 1mm gap. But having said that i'd re-measure the lugs to make sure. 21mm seems a bit of a odd size ??.
Fit the 22mm, little known fact about the Omega mesh, the endlinks being a row of flexible loops can bend in with very little effort, you'll get that 1mm of room rather easily.
I know that the measure is right , smallest size has 19mm lug, medium has 20mm and full size has 21. Thats sick to make lug size thats uneven, but that is the size of old omega Aqua terra models ;(
Ok Nice ! I hope that you are Shure aboute this, because i Will order à 22 mesh bracelet then and squize it à bit
Np i'm strong. But i have to check one last thing. I have small wrists. And must know what the narrowest lenght is on à 22 mm mesh is. Because it Seems that the mesh only could be adjust at the employment. Its not like an ordinary bracelet that you can remove pieaces
It can be adjusted to fit a mouse if needed, because the mesh rows are all the same, you can actually cut off excess rows as much as you like, best done by a professional, but not that hard.
