Any information you could share would be terrific. The clasp is clearly marked 1153/138 and the end-clips 155. However the last links before the end-clips are 22mm. Thanx for your help, Miki
Apparently you flipped-flopped on this. Is it an 1159 or a franken? It can't be both. Someone break the tie, please.
I never changed my mind about that one: I said it WAS a 1159... before swapping the clasp, so it's not a 1159. To me, a bracelet with a wrong clasp is a Franken...
Are you saying that the bracelet and ends, not withstanding the clasp, was originally an Omega 1159. I'm not being critical, as I'm only trying to figure this out. Miki
@uwsearch is correct in both statements. Excluding the clasp, the bct looks exactly like a 1159 that's, with the 22mm ends, usually equipped on the Speedmaster MkIV style cases. It also looks bent and worn out. The 1153/138 is of different style and usually for the Dynamics. The whole thing is certainly usable if you keep it, and surely worth something for parts.
