Dear OF I'm trying to identify this bezel, but using Moonwatch Only i can't work it out. The Dot Below 70 suggests a B5 or B6 (with even the dot appearing to be more to the left than centre of the 0 above). The dot above 190 suggests a B6, as does the short 5 in 500 . BUT... either way those bezels would suggest to have an Accented È in Tachymètre, which i don't see. Any thoughts? Thanks in advance
I assume it's possible that it is a bezel for a different watch too. Is the diameter of this the same as a standard Speedy bezel, or is it slightly smaller?
Euhhh.. are you sure its fake? Besides the È, anything else that gives it away to be so sure? Its on a speedmaster that besides its second-arm otherwise appears to be legit.
Well, it could be for a different watch like @rcs914 mentioned. But if it’s supposed to be for a Speedmaster, then yes I’m sure... at least until I’m not . As you pointed out, this bezel layout/configuration just never existed. Even if the layout were done right, the type looks small and off.
