Hi, I've read the thread 'learn how to fish', which I found really helpful however I'm struggling to find anything on how to look at the movement. One of Desmonds write ups state that you should look for colour variation. What other signs should I look out for? What should the weight look like? Some weights I've seen appear dull were as others appear to have a high polished edge. My watch repairer states that I should look out for scuffing on the movement or on the weight as this will be a clear sign of neglect of the watch. Just curious to know what scuffing would look like. Look forward to your responses!
Top of the rotor will have scuff marks and inside of the case back will have circles to match Here is a few nice movements from a few of my watches that are all the same matching colour. ( notice the crisp edge above "Omega watch co Swiss" on the rotor ) Constellation Seamaster ------------------------------------------------------------------------------------------------ Now from a thread I found by searching "worn rotor" ( notice different colour parts and scuffs above wording on rotor ) https://omegaforums.net/threads/omega-constellation-168-019-from-c-1969.69969/#post-880763
This case-back seems have the swirls consistent from center to outer edge. But it does have an outline off the edge of the weight about half the way from the outer edge
Rotor wear is not the be all and end all of a nice watch. It may have been fixed a service or two ago or could be current. You have to weigh up the whole watch as I have seen nice dials with rotor wear that I would still buy. Movements can be fixed but over polished cases and damaged dials can't
Thanks very much, will read the thread. Still getting used to the forum so will check this thread out. Thanks for your advice
I listed a few tips some time ago in this thread: https://omegaforums.net/threads/spotting-problems-with-watch-movements.36339/#post-412838 Cheers, Al
