8270 clasp pin
I have an 8270 BOR with 70 end links. I purchased the bracelet several years ago, put it away, then forgot about it.
I am in the process of putting the bracelet onto my Pie Pan. Doing this today, i saw that the pin that connects the two parts of the clasp is missing. I have tried searching, but keep getting spring bars, which are no what i need. I had a generic bracelet and tried using that pin, but it was too wide.
Any suggestions?
Thanks!
Its steel wire, friction fitted then the ends of the tubes crimped ever so slightly so prevent it coming out.
Actually, not steel wire, but stainless steel.
Lots of things online. I think that the width of the hole the pin goes into clasp hole is the key to sizing. I'll continue searching.
Laugh away, but I have found that large paperclips are an alternative. Diameter generally seems to be the same as needed at least on the couple I wanted to try this on. Just cut to size and hammer into place.
If you don’t know what you’re doing just take it to a local watchmaker. It’s a quick job and the small amount you’ll pay will likely be much less than the time you’ll spend trying to sort it yourself.
Use only stainless steel hinge pins on bracelet hinges.
Any suggestions?
Thanks!
Find a local watchmaker. He will have multiple trays of parts like this. One of them will work.
Here is the image of my bracelet. There is no watch repair available where i live. The watch could use a service anyway, so i'll send both in to get sorted. I do have a black lizard strap that has worked well since i purchased the watch.
The paperclip fit! Small, sharp protrusions left though. I m going to send the watch and bracelet for a service. The watch is past due, and they can sort out the bracelet then. Thanks!
