Every time you hear that "click" while winding the watch manually likely means that, if you continue to wind after the click, you are starting all over again. If you are concerned that you might harm the watch by over-winding it, stop worrying. Wind it all you like. If you are only getting 3 to 4 hours of run time after manually winding it 40 to 50 turns, the watch needs to either go back to the seller, or the repair shop. Just make sure to choose your repair shop carefully. About 90% of the "watchmakers" currently active are lost when it comes to servicing watches like your Omega. Stay away from the watch repair kiosk at your local mall. Generally, these kiosks use shops that are incapable of doing anything other than swapping out cheap quartz movements! Before I end up wearing the brown helmet
, let me say that there are exceptions to this rule.
