  1. knappo1307 Jan 19, 2014
    Firstly I'd like to say I'm a relative newbie on the Omega Forum. I'm a regular on The Rolex Forum and Watchuseek. So thank you kindly for any information I can get. My question is: Does anyone have a general idea of the power reserve on a full wind a 1954 Caliber 266 movement has? It has been serviced within the last year. I will enclose a picture of the movement also. Thanks again for your responses. Regards Jason
  2. ulackfocus Jan 19, 2014
    knappo1307 likes this.
  3. knappo1307 Jan 19, 2014
    Thanks for that info Dennis...
  4. Archer Omega Qualified Watchmaker Jan 19, 2014
    You might be a little disappointed if you expect to get 43....Omega calls for the Cal. 266 to have a 32 hour power reserve. I would take the info on his site with a grain of salt...
    Now it's not unusual for a well serviced movement in good condition to run longer than the stated power reserve, but not 11 hours longer - unless someone has installed a longer mainspring (non Omega obviously).
  5. knappo1307 Jan 19, 2014
    Thanks Al... I've posted this elsewhere also, and that seems to be the general response also. Given the age, and the condition of the mainspring 43 hours seems a bit ambitious. I've given it a full wind, and I'm going to test it. It's not a daily wearer, and yesterday wound the watch around 10-15 full winds and got about 20 hours out of that. Thanks for the info....:thumbsup:
  6. John R Smith Jan 19, 2014
    My 26x and 28x movements take a bit over 30 winds from zilch to fully-wound, and then they run 34 hours or so till they stop.
  7. knappo1307 Jan 19, 2014
    Thx for the response John...
  8. knappo1307 Jan 21, 2014
    Just a quick follow up, a full wind yielded about 36 hours. I'm happy with that, and thank you for your responses. Best Jason
  9. cicindela Steve @ ΩF Staff Member Jan 21, 2014
    That is pretty good and typical of the ones I have. Some are slightly better, but not much. Though as Al indicates, no telling what springs were installed over the years.
  10. cicindela Steve @ ΩF Staff Member Jan 21, 2014
    How about a picture of the front of this watch. :thumbsup:
  11. knappo1307 Jan 21, 2014
    Sure... The picture does the watch no justice, it's a real beauty. And the hour markers have a great twinkle when the light hits them on the wrist. Thanks again all.....
  12. knappo1307 Jan 21, 2014
    It's 18kt rose gold...
  13. John R Smith Jan 21, 2014
    It's a big one, too, isn't it? The cal 266 is fitted with a brass spacer, so I would guess this must be 36mm or more in diameter. A rather special dress watch from the early 1950s with guilloche dial.
  14. knappo1307 Jan 21, 2014
    37mm, is the measurement of the custom case. Case and crown are not Omega...
  15. Archer Omega Qualified Watchmaker Jan 21, 2014
    4 hours past the stated reserve is not that unusual - companies tend to err on the shorter side when they state the power reserve.
    It could be a non-standard replacement spring inside, and often if someone doesn't have access to genuine parts, or is too cheap to buy genuine parts, they will find something "close" and use that instead. I do this when branded mainsprings are no longer available, usually due to the brand going out of business or having changed hands - an example would be say Bulova - you won't find any newly made Bulova springs for their vintage watches, so it's either NOS or just picking something close.
    Nothing really wrong with this approach if the branded spring is not available. Width and strength (thickness) are the key dimensions, and length tends to be the one that can vary the most from the original spring without performance issues.
    Anyway, nice watch!
    John R Smith likes this.
  16. knappo1307 Jan 21, 2014
    Great, informative post. Many thanks Al.......
  17. Tony C. Ωf Jury member Jan 21, 2014
    knappo1307
    A little post-processing on your gold 266 image. Hope you don't mind.
    Cheers,
    Tony C.
    [​IMG]
  18. knappo1307 Jan 21, 2014
    Great job, Tony !! Don't mind at all
