1950s seamaster 2759 crystal replacement help
Hello guys.
I want to replace the crystal on this one and i don’t know how to do it. Is it pressed? I don’t want to remove the bezel because i know they can brake. I ordered the crystal on cousins and im quite sure it is the right one.
Thank you in advance!
Yes they press in, ideally with a crystal press. Removing the bezel wouldn't help anyway as the crystal seats into the case itself.
You might be able to do it by hand and then again you might be buying another crystal too.
That looks like a really high dome. Are you sure thta is the correct crystal?
It does look quite high doesn’t it.
Crystal height should be 4.3 mm - this looks quite a bit taller than that...
