Thank you in advance to the community and all those that continue to help many of us learn. I have a deposit on the watch pictured below. A 145.012 that is described as complete with box and papers and purchased from the original owner. I have a copy of the MWO book and have reviewed the watch against the MWO references and to my still untrained eyes everything appears to be in order, serial number range, DON, 1039 with 516 end links, flat seconds hand, spaced T dial (missing lume), pushers, caseback, case appears unpolished.
For the papers the medallion booklet is included with the information filled out from the retailer. The serial number listed on the medallion card matches the movement number and appears in the correct range. However the reference number written by the retailer indicates 6126 which I believe would be a reference to a seamaster of the same time period and also a cal 321. The dealer I am working with indicated this is not uncommon to see, but to me it seems odd.
Questions:
- Have others heard of this or seen before, or do you think this is more likely to mean the papers are actually from a seamaster and the movement has been swapped?
- Is the only way to resolve by getting the archives from Omega?
- Am I missing anything else? From the movement picture I also noted that part 321.1774 (p 42 of MWO) is not shown in the picture. The watch was being serviced when the pictures were taken and I also need to verify if it had been removed.
Thank you,
