Ca Vanezze , you can ask him if they have been redone. He will tell you. But they look ok to me, it is the little silver rings around the subs I am not sure of . The outer bezel I think from the Movado range of the same type.
This is all kinds of wrong. The hands should be silver metal,not painted orange, and the hour batons should have a central lume insert. Subdials are certainly redone - numbers should be all upright and 3-6-9 lines should extend to the center of the chrono minutes subdial. The orange bezel may be correct, however. On balance, avoid.
