  1. MSNWatch Vintage Omega Aficionado Staff Member Apr 6, 2014
    The vertical brushing is found in other connie dials in other case references as well - both piepan and non piepan dials.
  2. gatorcpa ΩF InvestiGator Staff Member Apr 6, 2014
    The crown on your watch is correct and original, but the gold plating is very worn. This is common with vintage watches. One of the main reasons why most collectors accept watches with replaced crowns, so long as the replacement is correct for the reference.
    It's a lot like replacing tires on a vintage car. Some collectors will insist on the original, no matter what the condition. Others will want to drive the car occasionally, so modern replacement tires need to be fitted.
    To satisfy both kinds of collectors, be sure to save the original crown with the watch.
    Do a search on Ofrei's site for "168.025". You'll find it.
    "Omega Crown 43068 Yellow, Fits Case 167.015 and 168.025 New
    Fits Case numbers 167.015, 168.015 and 168.025
    Crown 8100/1194Y Omega 43048 fits the old version of case and 8100/1220Y Omega 43068 fits the new version of the cases listed. Today Omega list old 43048 and new 43068 as being replaced by the crown 42524. The terms old and new are used in the 1972 B. Jadow listing of Omega crowns.
    For 18kt gold case and gpld cap and plated cases 166.0105, 167.015, 167.0015, 168.025, 168.002"
    Hope this helps,
    gatorcpa
  3. Skv Apr 6, 2014
  4. hoipolloi Vintage Omega Connoisseur Apr 6, 2014
    Sure you can, but thing is not simple like that, the new crown can be "too yellow" (18k gold color) and you will prefer the old and worn one because it has the right matching color with the case.
    Let's wait and see.
  5. Skv Apr 6, 2014
    Just bought this crown for an incredible EUR 8,80 including shipping. The seller failed to provide sufficient information in his ad, so I assume that not many buyers found the ad. I think that it is the 4204. He claims that it is an unused original Omega crown, goldfill, tap90. If I don't like it or if it doesn't fit, I'll sell it on the Bay. http://www.mediafire.com/file/mm3gmu3zyy2/Omega_Constellation_Crowns.pdf
    [​IMG]
  6. woodwkr2 Apr 6, 2014
    If you do this operation yourself, you'll want to be careful about a few things:
    1)Take care not to scratch up the sides of the case in removing the crown
    2) use it as an opportunity to clean up the parts--you don't want to introduce dirt into the case and movement by replacing the crown
    3) once you've tested and friction fit all the parts, you'll want to loctite the female stem into the crown (and a proper pin vise is invaluable here).
    This is all, of course, assuming that when you remove the original crown, you find both halves of the split stem in good condition and do not need to replace anything there.
  7. Skv Apr 6, 2014
  8. woodwkr2 Apr 6, 2014
    Enjoyed that top link. Especially these wise words when it comes to anything related to watches:
    "There is No need to "put your shoulder" into anything connected with fine watchmaking...[ NEVER force anything, sit back and think, if you are forcing or using "your shoulder" you are quite simply doing it WRONG... Watches are designed to be taken apart easily, do not make your job any more difficult than it is by not thinking your job through before you start. The time spent thinking before you attempt to take apart your watch is more than the time and money required to "fix" damgage that occured because you the "watchmaker" did not take the few minutes thinking before you start.
    A question to all....
    Why do "watchmakers" make things so difficult on themselves?? Quit prying, gouging and otherwise brutalizing fine timepieces. Basically quit trying to re invent sealing wax. A little thought and life is simple. The watch tools are there for a reason, some have more than one use."
    Skv likes this.
  9. Archer Omega Qualified Watchmaker Apr 7, 2014
    If the cut end of the stem is prepared properly, a pin vise is all that is needed to secure the crown to the stem. I rarely use Loctite on stems, and if I do it's usually on a quartz watch where the stem is fragile enough that you can't apply sufficient torque to tighten it without snapping the stem. Most of the time, Loctite is not needed.
  10. Skv Apr 8, 2014
    [​IMG][​IMG][​IMG][​IMG]
  11. Skv Apr 8, 2014
    [​IMG]
    [​IMG]
    One small downside I noticed is that the material underneath the bezel on the bottom of the face is damaged. Does this compromise ability to keep dust from coming in?
    cristos71 and Privateday7 like this.
  12. Privateday7 quotes Miss Universe Apr 8, 2014
    Very nice watch !!!........ I couldn't see what you mean by material underneath bezel. Tension ring? (It is the ring that hold the crystal in the place)
  13. Skv Apr 8, 2014
    No, check the edge of the case underneath the bezel. The part in between the lugs where the strap is placed. Is this repairable?
    [​IMG]
  14. Skv Apr 8, 2014
    it is like the tension ring is lifted up a bit, now thay I assess it more closely.
  15. Privateday7 quotes Miss Universe Apr 8, 2014
    Now I see it. Never seen like this before, probably place where the tool place the tip to open the top.
    Others experienced with open top watch probably could shed more light
  16. gatorcpa ΩF InvestiGator Staff Member Apr 8, 2014
    I don't see anything wrong with it. My watch is like that also. The bezel hangs over the edge of the case a little bit and there is supposed to be a gap there.
    It's possible that's it's a little scratched up from a watchmaker lifting up the bezel to clean or repair the movement.
    Hope this helps,
    gatorcpa
    Skv likes this.
  17. ulackfocus Apr 8, 2014
    Looks good to me. :thumbsup: Nice score!
  18. Privateday7 quotes Miss Universe Apr 8, 2014
    Jelle86, now the experts has chime in, stop worrying....and start enjoying :thumbsup:
    Skv likes this.
  19. Skv Apr 9, 2014
    You just made my day..! Now I can enjoy it fully!
    To celebrate it, I just ordered a dark brown unpadded genuine lizard strap by Hirsch. Updates will follow.
    I cannot remember being as pleased with a watch as I am with this one. It just breathes quality and luxury. I can really recommend you guys to get one. Just wow. :D
    Privateday7 likes this.
  20. Privateday7 quotes Miss Universe Apr 9, 2014
    You know that the first symptom of addiction, don't you?;)
    It's a very slippery slope from there. Especially if you continue to hang around this forum.....::stirthepot::
