I have a lizard band which came unglued. Have any of you had the problem? If so, what type of glue did you use? Secondly, on a watch with thick lugs, do you use a thicker band?
On a Hirsch open end strap one is supposed to use acetone to activate the glue. Otherwise one can use super glue or Gorilla glue I suppose. Concerning your second question: it's hard to give an answer without a specific watch or strap in mind. Everything's relative...
