>> Using a car, which engages a clutch
>> turning at hundreds of revolutions per minute,
>> with hundreds of HP behind it,
>> to move an object weighing thousands of pounds..."
Well, this is what happens when you use the word "clutch" loosely, in a post that is supposed to explain that exact principle in more than two words -- people go to what they know. Thank you for making the point for me.
>> in a watch movement,
>> where the mechanism is turning at 1 revolution per minute,
>> with a very small torque,
>> to move an incredibly small load
Now you are talking -- this is how you should have started, and you are still behind...
A clutch may be spring pressured, but what is really the way that clutch works? Pure pressure and friction? What kind of spring -- spiral, blades, compression, torsion, tension? Any mechanical intertwining between the parts engaging? Conical, flat, cylindrical? Wet vs dry?
I suggest taking a look here -- the ingenuity and creativity of people over time created an extremely large diversity of clutches (and this article only scratches the surface). You cannot just throw the word around and expect people to understand what you mean.
https://en.wikipedia.org/wiki/Clutch#:~:text=A clutch is a mechanical,drive shafts or line shafts).
>> The fact that you seem to be the only one who doesn't understand how this works
Yes, due to your poor explanation of the core principle.
And the rest of the people are too in awe of your magnificent qualities to think and understand what they are reading, or too coward to express any problems with the subject being explained.
You want to treat something technical? Do it rigorously, and ask yourself every time you write: what is the principle behind it, and am I writing it clear enough that a sixth grader would have no problem understanding? Everything else is self aggrandizing...
And since I smell a bit of a God complex here, remember than even God wrote 783,137 words (??) in the Bible, more or less. If he was humble enough to spend the time and the effort, I think this should not be a problem for you.
And I am exactly the opposite of religious, the comparison just comes in handy.
I sincerely do not care who anyone is -- if they write sloppy, I will point it out. Feel free to do the same to me or to anyone else -- it is one of the basis of the Western Civilization as we know it, even though it is being slaughtered at the present moment...
Don't add to the misery of the world.
And if this site is for specialists only (I am not a watchmaker, I am just an MSc engineer) and if you all know this stuff inside out (I am new to watches, but I want to learn, which seems to be a problem around here), why do you even bother???
This stupid argument really borders on the imbecilic... don't bring it up again.
