Odd - looks like when the dial was reprinted, it was not done even close to straight. The stem lines up with the crown wheel on the movement photos, so the movement appears to be in the case straight. But the stem does not line up with the "3" on the dial...
Could dial feet sheared off as well, but then the watch would not likely run as the dial would bind on the sub-seconds hand.
Also looks like one case screw is missing or sheared off.
