Battery change interval? - SMPq
  1. Matt-C Sep 17, 2014
    Hi
    My SMPq is just approaching 2 years old. I do use it quite frequently in water so figured I should get it pressure tested at least.
    Although there's no sign of the EOL indicator would it be worth changing the battery at the same time? I know from reading other threads/forums, (are there other forums!!) some people have only had 2 battery replacements in 8/10 years but is this something that would be worth doing every 2 years regardless or should I stick to an annual pressure check and just change the battery when prompted, given the potential for cell leakage?
    Cheers
    Matt
